« ตอบกลับ #2 เมื่อ: กรกฎาคม 25, 2011, 16:49:21 »
แล้วแต่ชอบครับ บางคนก็ว่ามีติ่งก็ดีทำให้ไม่ดูโล้น .. ไม่รู้ honda motor จะจัดแบบไหนให้พี่ไทย แต่ที่แน่ๆรู้ว่าวันนี้มีงานเข้า FD
Honda to recall 200,000 cars globallyTOKYO --
Japan's Honda Motor said Monday it would recall about 200,000 passenger cars globally due to defective engine parts.The company said it had received 63 customer reports in Japan of engine malfunctions as a result of the defect, but said none had led to accidents.
In Japan alone, the car maker will recall more than 50,000 units of three models -- the Stream,
Civic, and Crossroad --
that were produced at its domestic plants between July 2008 and July 2010, it said.
Honda will exchange engine bolts that may cause trouble with the motor cooling system and that could eventually cause the engines to stop.
"Globally there are some 200,000 cars, including the 50,122 in Japan, with similar trouble," a Honda spokesman said, adding that it would recall about 100,000 units in South America and 6,800 in Europe.
The other vehicles are being recalled in the Middle East and Africa, but the recall does not cover markets in North America.
