บอดี้Porches วางเครื่อง V8
Ferrari คงมีหนาวครับ
ครับ ..... ดูบอดี้กับสเป็คเต็มๆBody:-2 seated coupé with integrated roll-cage
-2 racing type bucket seats
-Aluminium doors and front hood
-Carbon fibre engine cover and rear spoiler
Engine:-Lightweight-8-Cylinder-90°-engine with racing DNA
-180° crankshaft Flatcrank
-4,5 Liter displacement
-Power output 404 kW (550 bhp) @ 8500rpm
-Maximum torque 500 Nm @ 5400rpm
-Aluminium crankcase and cylinder heads
-Water cooled, cylinderheads and engineblock cross flowed
-4-valve system with spherical layout
-4 camshafts with hydraulically timed valve system for in- and outlet
-Hydraulic valve tappets
-Dry sump oil lubrication with two windage trays for each of the 4 chambers
-Individual chamber oil suction with 2 suction intakes
-Waterpump, generator and AC compressor are directly driven of the Engine (no belts), located at the lowest position
-Sequential fuel injection system
-Individual cylinder ignition coils
-Electronic engine management system
-Electronic throttle control system per bank with 2 butterflies
-3-Way catalytic converters with stereo closed loop lambda control
-On-Board-Diagnosis for continuous monitoring of the exhaust system
![](http://pictures00.topspeed.com/IMG/crop/201003/ruf-rgt-8-2_180x130w.jpg)
