« ตอบกลับ #5 เมื่อ: มิถุนายน 19, 2009, 17:08:11 »
..........ABS li. showing in dash board...........the best way to tracing down
is let the OBD scan through your car's ECU (perform by dealers or any
standard garage) and the results may diagnostic as following:-
- ABS wheel sensors malfunction/ECU would report you precisely which
wheel was damaged
- ABS pump failure
- ABS open/closed circuit **** often found on this item both European/
Japanese cars
.................and those items are causing ABS warning shown but thier
wouldn't making any harmful to you........please do remember one thing
that our motorist 've been driven without ABS more than 60 years!!!
