ผู้เขียน หัวข้อ: Is this the upcoming model ? Almera (L02B) ----> มาร์ชซีดาน  (อ่าน 12956 ครั้ง)
ออฟไลน์ สมาชิกคนที่2455
  • กระทู้: 1,775
Re: Is this the upcoming model ? Almera (L02B) ----> มาร์ชซีดาน
« ตอบกลับ #30 เมื่อ: กรกฎาคม 21, 2011, 01:17:52 »
ตัวนี้ญาติฝั่งอเมริกา ALL NEW 2012 NISSAN VERSA
Mechanical
1.6-liter DOHC 16-valve 4-cyl. engine
    -Dual fuel injector system
   - Continuously Variable Valve Timing Control System (CVTCS) on intake and exhaust valves
 5-speed manual transmission or Xtronic CVT® (Continuously Variable Transmission)
Vented front disc/rear drum brakes
Independent front strut suspension with stabilizer bar
Torsion beam rear axle with integrated stabilizer bar
Vehicle-speed-sensitive electric power steering
Exterior
15" wheels with P185/65R15 all-season tires
Multi-reflector halogen headlights
Energy-absorbing body-color front and rear fascias
Interior
AM/FM/CD audio system with auxiliary audio input jack
Air conditioning
Trip computer (Average MPG, Current MPG, Distance to Empty)
Tilt steering column
Rear window defroster
Front door pockets with bottle holders
Front and rear cup holders
Digital clock
Auxiliary 12-volt DC power outlet
Cloth seat trim
Safety
Nissan Advanced Air Bag System1 with dual-stage supplemental front air bags with seat belt and occupant-classification sensors
Driver and front-passenger seat-mounted side-impact supplemental air bags
Roof-mounted curtain side-impact supplemental air bags for front and rear-seat outboard occupant head protection
Anti-lock Braking System (ABS)
Brake Override Technology (BOT)
Electronic Brake force Distribution (EBD)
Brake Assist
Vehicle Dynamic Control (VDC)2 with Traction Control System (TCS)
3-point ALR/ELR passenger seat belt system (ELR for driver)
Front seat belts with pretensioners and load limiters
LATCH System (Lower Anchors and Tethers for Children)
Zone Body construction with front and rear crumple zones
Hood-buckling creases
Energy-absorbing steering column
Pipe-style steel side-door guard beams
Tire Pressure Monitoring System (TPMS)
source : http://www.nissanusa.com/microsite/versasedan/#/home
