ผู้เขียน หัวข้อ: spec ของ Toyota FT-86 มาแว้ววววว  (อ่าน 7725 ครั้ง)
ออฟไลน์ Tommy Tich
  • กระทู้: 51
« เมื่อ: พฤศจิกายน 01, 2011, 06:06:37 »
Power/weight:
HP: 147kw (200ps) / 200hp @7000rpm
Torque: 205nm (151 lb/ft) @ 6600rpm
Weight:
2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
2706 pounds for higher trim manual
Columns:
First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
Top Section:
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
Top spec manual is 1230kg, auto is 1250kg.
Low spec manual is 1210kg, auto is 1230kg.
Then its turning radius.
High spec rides on 17" wheels and low spec on 16.
Second Section:
This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks premium unleaded and 50L fuel tank.
Fuel consumption base model:
13 km/l
30.58 mpg
49.21 kmg
Fuel consumption top model:
12.4 km/l
29.17 mpg
46.94 kmg
Third Section:
This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
High spec brakes: ventilated discs front and rear.
Low spec brakes: ventilated front, non ventilated rear.
Last Section:
Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
MORE THINGS OF NOTE:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
LSD on all MT cars
Stability control standard
Only 2 speaker audio on base car
High Spec:
Has "high-quality fabric" (上級ファブリック).
Option for leather heated seats with Alcantara inserts.
Steel door sill insert / scuff plate (ステンレス製ドアスカッフプレート)
Interior metallic door handle inserts
Carbon fiber center console trim
Door courtesy light
Knee pad on console
The "Customize Grade" at the bottom is interesting:
the "customize grade" bare bones model is 1190 kg !!
Unpainted bumper
16 steelies (says ornament-included, guessing it includes the logo)
plastic steering wheel
NO A/C (only a heater)
Power door locks
Sunvisor (no vanity mirror)
No speakers
the car in fact does require premium unleaded gas (無鉛プレミアム)
the rear seat is one piece and is foldable (一体可動式)
did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター)
Source: ft86club
ออฟไลน์ beeday
  • กระทู้: 520
Re: spec ของ Toyota FT-86 มาแว้ววววว
« ตอบกลับ #1 เมื่อ: พฤศจิกายน 01, 2011, 09:37:25 »
ขอบคุณสำหรับข้อมูลนะครับ
ผมเทียบราคาแล้ว
2,498,000.00 JPY   =   985,257.23 THB
2,600,000.00 JPY   =   1,025,487.91 THB
2,930,000.00 JPY   =   1,155,764.82 THB
มาไทยนะเท่าไหร่กันนะ? ^^"
ออฟไลน์ joufo
  • กระทู้: 1,255
« ตอบกลับ #2 เมื่อ: พฤศจิกายน 01, 2011, 09:41:08 »
มาไทยก็เปลี่ยนคำว่า JPY เป็น THB ครับ
เช่น 2,498,000 JYP
ก็เป็น
2,498,000 THB ครับ
 ;D ;D
ออฟไลน์ prai
  • กระทู้: 3,154
« ตอบกลับ #3 เมื่อ: พฤศจิกายน 01, 2011, 09:47:20 »
ใช่ครับถ้าเป็นรถปกติที่ไม่ใช่ไฮบริดก็เปลี่ยนสกุลเงินเป็นบาทได้เลย
ออฟไลน์ art_duron
  • กระทู้: 990
« ตอบกลับ #4 เมื่อ: พฤศจิกายน 01, 2011, 09:53:44 »
สังเกตตัว low spec สุดๆสิครับ มีล้อเหล็กกันชนดำด้วย 555+  ;D
เหมาะนำมาแต่งแบบไม่ต้องกลัวเสียของ  ;D
ออฟไลน์ keng.
  • กระทู้: 3,551
  • ฅ.ฅนรักรถ
« ตอบกลับ #5 เมื่อ: พฤศจิกายน 01, 2011, 12:52:19 »
ผมเทียบราคาแล้ว
ราคานี้ไม่ใช่ของ FT-86 นะครับ
มันเป็นของ MX-5,RX-8 และ CR-Z ครับ
ออฟไลน์ Cross MPV
  • กระทู้: 325
« ตอบกลับ #6 เมื่อ: พฤศจิกายน 02, 2011, 10:20:00 »
แต่ผมไม่ค่อยชอบไฟท้าย FT-86 เลยอ่ะครับ อยากได้โฉบๆ ใกล้เคียงตัวคอนเซปมากกว่านี้
Find a vacuum and fill it.
methus zaa
« ตอบกลับ #7 เมื่อ: พฤศจิกายน 02, 2011, 10:24:13 »
2ล้านต้นๆนะ ผมจะเก็บตังซื้อเลย แต่เปลี่ยนไฟท้ายเป็น BRZ
« ตอบกลับ #8 เมื่อ: พฤศจิกายน 02, 2011, 11:08:29 »
อยากได้จังเลยครับ สืบทอดตำนาน AE86  ;)
