นี่ไงครับ spec รถที่ผลิตโดยคนไทย ส่งขายไปยังต่างประเทศด้วย
ENGINE : GASOLINE (LPG,NGV-Optional )
Daihatsu EB,EF four strokes : 550 cc , 650 cc
Cooling System : water-cooled
No.of cylinders and arrangement : 3 in-line
Tyres : 10"tyres/500/10, 12"tyres/145/65R 12
Windshield : D.O.T. Approved Laminated safety glass
Maximum speed (kms/hr) : 60-100
Fuel consumption (at 60 kms/hr) : 10-15kms/lt
Fuel tank : 30 lt.
CLUTCH : Dry Diameter (mm) 160
GEAR : 4 forward all synchromesh , 1 reverse manual gearbox
SUSPENSION : Front - double shock coil sprint with hydraulic
Rear - Leaf springs and shocks
BRAKE : Rear - Disc Brake
ELECTRICAL SYSTEM : 12 volt internally regulated charging system, negative ground,
with key operated 12 volt starter motor
LIGHTING : High/Low beam headlamp, running lights, turn signals, instrument lights,
and hazard flasher
BODY AND FRAME CHASSIS : Steel Body and chassis from our factory
FUEL SYSTEM : Carburator
AUTO TRANSMISSION : Optional requirement
