Mitsubishi i MiEV จะได้ผลิตในไทยมั้ยครับ เพราะเห็นน้อง i จอดอยู่คันหนึ่งที่ MMTh นานแล้ว
Mitsubishi i MiEV
Technical Specifications Overall Length x Width x Height: 3395 x 1475 x 1600mm
Curb Weight: 1080kg
Seating Capacity: four
Maximum Speed: 130km/h
Cruising Distance with a single charge (10-15 mode): 160km
Motor Type: Permanent magnet synchronous
Maximum Output: 47kW
Maximum Torque: 180Nm
Drive System: Rear-wheel-drive
Battery Type: Lithium-ion
Total Voltage: 330 Volts
Total Energy: 16kWh
The i MiEV is based on a Japanese model petrol powered car the Mitsubishi i, which is designed to conform to Japanese regulations known as K Class, and was chosen as the starting place for a full electric vehicle because of the suitability of the vehicle layout.
It?s smaller than Toyota Yaris.
The i MiEV is designed for city commuting, and has a range of 160 kilometres on a fully charged batter pack.
ไปดูเพิ่มเติมที่นี่เลยครับ
http://www.caradvice.com.au/26642/2009-mitsubishi-i-miev-first-steer/
