มันเขียนที่กระป๋องเลยว่า เหมาะกับรถที่มี DPF
Modern Diesel engines may be fitted with a Diesel Particulate Filter (DPF). These DPF filters, form part of the latest generation systems, designed to clean exhaust emissions in many late model diesel vehicles.
Vehicles fitted with DPFs generally require a Low or Mid SAPS engine oil. SAPS stands for Sulphated Ash, Phosphorous and Sulphur. A low SAPS engine oil has a lesser amount of these elements than a standard engine oil. The levels vary depending on the type of oil needed. Low SAPS oils are generally used in modern turbo turbo diesel engines that are fitted a diesel particulate filter or in modern petrol engines to assist in fuel economy gains.
