สูตรของ V-Power น่าจะเป็นแบบนี้นะคับ
คือ มีส่วนผสมของ Gas to liquids (GTL)
GTL Gasoil
GTL Gasoil is an alternative and economic diesel-type fuel that will contribute to the diversification of diesel fuel supply. It can be blended easily with conventional, oil-based diesel and used in the existing diesel distribution system. Shell has already blended some GTL Gasoil (from our plant in Bintulu, Malaysia) into the
Shell V-Power Diesel we sell to customers at over 5,000 sites in
Europe and Thailand. GTL Gasoil can also be used by refineries to upgrade heavier fuel products. This is because of two of its technical properties – it has a
lower density and higher cetane number than conventional diesel. A further characteristic is that it burns with
lower sulphur dioxide, lower nitrogen oxides and particulate emissions than conventional oil-based diesel. This means that if used at higher concentrations it can be attractive for improving local air quality. Shell has already trialled 100% GTL gasoil with a number of city bus and taxi fleets.
ลองดูตามนี้นะคับ
http://www.shell.com/home/content/aboutshell/our_strategy/major_projects_2/pearl/process/
