ได้ข้อมูลมาประมาณนี้ครับ
ไม่รู้หมายความว่าเป็นเครื่องบล๊อค GR เหมือนกันรึเปล่า
4GR-FSE
The 4GR-FSE is a 2.5 L (2499 cc) version. Bore is 83.1 mm while stroke is reduced to 76.9 mm. Output is 215 PS (158 kW; 212 hp) at 6,400 RPM and 26.5 kg·m (260 N·m; 192 ft·lbf) at 3,800 RPM. This version also features Dual VVT-i, variable valve timing on both the intake and exhaust cams and an improved D4-S direct injection system.
Applications:
* 2004 Toyota Mark X (GRX120/125) (Japan)
* 2006 Lexus IS 250 & IS 250 C (GSE20/25)
* 2003 Toyota Crown Royal & Athlete (GRS180/181)(Japan)
* 2008 Toyota Crown Royal & Athlete (GRS200/201) (Japan)
* 2009 Toyota Mark X (GRX130/135) (Japan)
2GR
The 2GR-FE is a 3.5 L (3456 cc) version. Bore remains at 94 mm but stroke is reduced to 83 mm. Reported output varies depending on the vehicle application, but is approximately 285 hp (213 kW) at 6200 rpm with 289 lb·ft (392 N·m) of torque at 4700 rpm on 87 octane (R+M/2). This version features Toyota's Dual VVT-i, variable valve timing on both the intake and exhaust cams. Valves are driven by roller-follower rocker arms with low friction roller bearings, and a unique, concave cam lobe design to increase valve lift over the traditional shimless lifter type system of the 1GR-FE. This increases overall cylinder head height to accommodate the slightly taller roller rocker system. Moreover, the cylinder head is segmented into 3 parts: valve cover, camshaft sub-assembly housing, and cylinder head sub-assembly. As such, this valvetrain is used across all other GR engines with Dual VVT-i. Its service weight is 163 kg.
Applications:
* 2005 Toyota Avalon (GSX30)
* 2006 Toyota Aurion (GSV40)
* 2006 Toyota RAV4 (GSA33/38)
* 2006 Toyota Estima (GSR50/55)
* 2006 Toyota Previa (GSR50)
* 2006 Toyota Tarago (GSR50)
* 2007 Toyota Camry (GSV40)
* 2007 Toyota Sienna (GSL20/23/25)
* 2007 Lexus ES 350 (GSV40)
* 2007 Lexus RX 350 (GSU30/35)
* 2007 Toyota Harrier (GSU30/31/35/36)
* 2007 Toyota Vanguard (GSA33)
* 2009 Lexus RX 350 (GGL10/15/16)
* 2007 Toyota Kluger (GSU40/45)
* 2007 Toyota Blade (GRE156)
* 2007 Toyota Mark X Zio (GGA10)
* 2008 Toyota Alphard (GGH20/25)
* 2008 Toyota Vellfire (GGH20/25)
* 2008 Toyota Highlander (GSU40/45)
* 2009 Toyota Venza (GGV10/15)
* 2009 Lotus Evora (280ps & 350Nm using Lotus engine management, Sport Pack package redline increased to 7000rpm)
* Toyota Corolla (E140/E150) (for Super GT use)
**ที่มา
http://en.wikipedia.org/wiki/Toyota_GR_engine
